Minor request here. It would be great to have the pitch bend range extended from +/-12 to 24, or possibly 36. This is possible by using an extra modulation slot in the matrix from pitch bend to pitch, but it would of course be nice not having to sacrifice a modulation slot to achieve this extended pitch range.
and additionally: being able to set different values for 'UP' range and 'DOWN' range, so you can play with the same 'musical interval' one octave up or below the actual note / chord.
For example: bend up = 5 / bend down = 7
in this scenario, if you play a Cmaj chord, the fully PB up result will be a Fmaj chord above the original Cmaj chord, while the fully PB down result will ALSO be a Fmaj chord, in this case below the Cmaj chord. And yes, that's really nice.
Thanks again!
