Feature Requests
Re: Feature Requests
« Reply #460 on: July 04, 2021, 01:52:48 AM »
When I modulate the VCA with, for example, a LFO, I hear the Synth without playing a note. For me it would be more logical, when the VCA ist Gated by the Amp-Env. Because otherwise you hear random 8 or 16 notes.
maxter
« Reply #461 on: July 05, 2021, 09:44:33 AM »
This behaviour can be useful for some, for drones, "generative" stuff etc.
But it's possible to work around.
You can set the LFO amount to 0, then modulate its depth with the env3 for example. This way you can also have delayed onset, attack (fade-in), and release (fade-out).
« Reply #462 on: July 07, 2021, 07:53:37 PM »
Chorus delay line is to high , there is audible and very noticable delay between ths osc sounding fitrst and chorus kicking in a few mili-seconds later, should be reduced.
« Reply #463 on: July 19, 2021, 08:11:04 AM »
Making sure that this is on the radar for the final bug fix: fix filter range
 https://forum.sequential.com/index.php/topic,5362.msg53814.html#msg53814
« Reply #464 on: July 19, 2021, 09:06:03 AM »
It is now, thanks to you.
« Reply #465 on: July 28, 2021, 03:57:27 PM »
Another issue that needs to be resolved is that pitch bend and aftertouch should work on both layers of a 16-voice split Rev2 when using MIDI. (As confirmed by Mark Kono of Sequential support in case #65088: "At present you cannot address each layer via MIDI for separate wheel movement on both the Rev2 module and keyboard.")
I don't know if this is a feature request or a bug, so feel free to move it to the appropriate thread.
« Reply #466 on: November 13, 2021, 12:04:05 PM »
Hi
Many wavetable synths are now offering to upload user waveforms -
Novation peak
Arturia microfreak
Korg wavestate
Any plans to implement this for the Prophet Rev2?
  • 1687
« Reply #467 on: November 13, 2021, 03:03:14 PM »
Hi
Novation peak
Arturia microfreak
Korg wavestate
The Rev2 has analog oscillators, unlike the other synths listed.
