Well Sacred Synthesis, It'd certainly be easy to run off and hide away all winter long with the P12
Actually I'm taking my time on it. I knew when I got it that it could divert me away from my other instruments and I didn't want that to happen. So I'm sticking with a routine of making a slow circle once a month around my set up. Next up, PO8.
By the way, that wah wah lead towards the end is a factory patch on the P12. I think it'd be my favorite patch if I played in a funk band
. The rest are either modifications or my own.
The DM12 actually can make some really nice guitar-ish sounds. Typically osc 1 is set both saw and pulse, then I add osc 2 which is pulse. Set it to pretty narrow- as you surmised. I modulate what they call "tone" of osc 2 with env 3 so that it changes like a string would. Also, add some ever so slight delay to it The notes are played as usual, but I'm using the units sequencer to play two additional notes for every note I play. You can adjust the slew between notes to get a bit of string/finger slide effect. But that option is largely contingent on temp. Too fast and it sounds muddy. Problem with DM's sequencer is that its really hard to adjust notes w/o using an editor (which I don't have or want). My favorite sequencer still remains the PEK's, as it allows so much flexibility, but I wish it was able to be sent midi out.
