Are you able to intentionally repeat the unintended skipping?
Hi dsetto,
Yes, I am able to intentionally repeat the skipping, but it is a very long winded process to go through. Carson did confirm this bug under 1.4.5.5 and thus released 1.4.5.6. However, I saw no change or fix with 1.4.5.6.
If anyone has the time and patience to to test this out it, and supply feedback on this forum it would be greatly appreciated.
SETUP:
System OS: Main OS 1.4.5.6, Voice OS 1.5, Panel OS 1.3 and SAM OS 1.1
Power Cycle your Tempest
Load a Factory Project
Initialise Project
Ensure System: Clock set as MIDI Clock Mode: Master
Set System: BPM source as Beat
Set System: Swing source as BEAT
Go into Beat Mode & Pads
Enter Swing and BPM data on these pads:
A1 56.3% 170 bpm
A2 60.4% 170 bpm
A3 64.6% 170 bpm
A4 62.5% 170 bpm
A5 60.4% 170 bpm
A6 58.3% 170 bpm
A7 56.3% 170 bpm
A8 60.4% 170 bpm
A9 default
A10 default
A11 56.3% 166 bpm
A12 58.3% 164 bpm
A13 60.4% 162 bpm
A14 62.5% 161 bpm
A15 64.6% 160 bpm
A16 50.0% 160 bpm
Enter time signatures on these Beats by holding Erase & Copy and selecting 10. Change Time Signature from menu and enter the following data
A1 4/4 2 bars
A2 4/4 8 bars
A3 4/4 4 bars
A4 4/4 8 bars
A5 4/4 6 bars
A6 4/4 4 bars
A7 4/4 2 bars
A8 4/4 2 bars
A9 default
A10 default
A11 4/4 4 bars
A12 4/4 8 bars
A13 4/4 6 bars
A14 4/4 4 bars
A15 4/4 4 bars
A16 4/4 1 bars
Enter Play List by holding Play List & Events
Select play mode as End: Stop Playback using the soft knob 4
Enter the following data:
1 / 1 Basic Beat 2 bars (bar 1)
2 / 2 Basic Beat 8 bars (bar 3)
3 / 3 Basic Beat 4 bars (bar 11)
4 / 4 Basic Beat 8 bars (bar 15)
5 / 5 Basic Beat 6 bars (bar 23)
6 / 6 Basic Beat 4 bars (bar 29)
7 / 7 Basic Beat 2 bars (bar 33)
8 / 8 Basic Beat 6 bars (35)
9 / 3 Basic Beat 4 bars (41)
10 / 4 Basic Beat 8 bars (45)
11 / 5 Basic Beat 6 bars (53)
12 / 6 Basic Beat 4 bars (59)
13 / 7 Basic Beat 2 bars (63)
14 / 8 Basic Beat 2 bars (65)
15 / 3 Basic Beat 4 bars (67)
16 / 4 Basic Beat 8 bars (71)
17 / 5 Basic Beat 6 bars (79)
18 / 6 Basic Beat 4 bars (85)
19 / 7 Basic Beat 2 bars (89)
20 / 8 Basic Beat 6 bars (91)
21 / 3 Basic Beat 4 bars (97)
22 / 4 Basic Beat 8 bars (101)
23 / 5 Basic Beat 6 bars (109)
24 / 6 Basic Beat 4 bars (115)
25 / 7 Basic Beat 2 bars (119)
26 / 8 Basic Beat 2 bars (121)
27 / 11 Basic Beat 4 bars (123)
28 / 12 Basic Beat 8 bars (127)
29 / 13 Basic Beat 6 bars (135)
30 / 14 Basic Beat 4 bars (141)
31 / 15 Basic Beat 4 bars (145)
32 / 16 Basic Beat 1 bar (149) ensure Stop Playback enabled
You might want to save a Project file at this point, if you dont want to input data again at a later point.
PRESS PLAY
About once every 4 plays of the Play List you will get a skip, you will have to concentrate and watch the time stamp which is very tedious.
I again did this test before posting here and I encountered these results:
Play 1: OK
Play 2: Skipped from Bar 108-113
Power Cycled
Loaded Test Project
Play 1: OK
Play 2: Skipped from Bar 40-43
Power Cycled
Loaded Test Project
Play 1: OK
Play 2: Skipped from Bar 22-27
Looking at that data you would say that transitions into or out of a 6 Bar beat was the cause. But on a previous test I have replaced the 6 Bar beats with 2 & 4 Bar substitutes, the skip bug then moved into 8 Bar beats and usually happened on the third time of playing.
If you do try this out and encounter the same issues, thank you very much for having the patience and time to do this.
