Envelope problem on prophet-5 module
xox
« on: August 28, 2023, 08:51:15 AM »
I am the new owner of a prophet-5 module.
I have an issue with patches that have a slow filter attack. Sometimes a note plays with a fast attack.
I have udpated it to the latest firmware, tried differents settings (last note priority, keyboard velocity) and used different keyboards via both midi din and USB but I still have the issue that occurs quite frequently.
Is it a known issue?
Re: Envelope problem on prophet-5 module
« Reply #1 on: August 28, 2023, 10:06:01 AM »
I'm wondering if it's a case of classic voice stealing...
Check page 45 of the manual... Key Priority Modes. Hopefully it'll help make sense of the issue...
xox
« Reply #2 on: August 28, 2023, 10:58:42 AM »
Thank you for your quick answer. It might be actually...
I did test with a patch with slow attack (both amp & filter)
Holding a 5-note chord, the 6th note is played with short attack once.
If I release this 6th note and play it again it will be played with slow attack just fine.
I've got the same behaviour in LAS and LAR modes.
« Reply #3 on: August 28, 2023, 11:14:28 AM »
This might help as well...
https://forum.sequential.com/index.php?topic=6209.0
« Reply #4 on: August 28, 2023, 12:16:17 PM »
Yep, most likely voice stealing ...
When pressing the 6 th note it takes over the envelope curve from the previous note
where ever the curve is at the moment.
Shorten the release will help a bit ...
Cheers !
« Last Edit: August 28, 2023, 12:17:55 PM by HockeBocke »
1976 MiniKORG700s // 1978 Prophet-5 rev.2 // 1981 KORG CX-3 // 1984 DX7 // 2020 Prophet-10 rev.4 // MoPho Box // 2 Creamware MiniMax // Creamware Pro-12 // 2 EMU-Proteus 2000 // EMU-Vintage Keys  // Casio VZ-10M // Roland VK-8M // Fatar SL 880 // Roland JUPITER-X
xox
« Reply #5 on: August 28, 2023, 10:28:00 PM »
Thank you all for your help. I had the same very clear answer from customer support.
Don't you think that it could be interesting to have an option to retrigger the enveloppe from its initial position when a voice is stolen?
