Known Bug or is my pro3 broken?
« on: March 07, 2021, 01:41:30 PM »
Hey guys, my pro3 sometimes holds a midi note out of noting and always keeps notes sustained. The unit is standalone without a daw or food pedal.
Is this a known bug or should I contact the support?
My unit also had faulty behaviour (sustained notes and the sound bypassed all envelopes and filters) which was fixed with a repair.
What do you think?
Re: Known Bug or is my pro3 broken?
« Reply #1 on: March 08, 2021, 12:45:15 PM »
I encountered an issue recently where, while I was playing notes while switching between mono- and paraphonic mode, the Pro 3 got into a weird state where one note was always stuck on, unless I played that note, which would turn it off while I was holding it down.  I had to restart the Pro 3 to get out of that state.
Probably not related to what you're seeing, and I only encountered this once.  Sharing in case there's anything that sounds familiar.
« Reply #2 on: May 16, 2021, 06:27:19 AM »
Sounds very similar to an issue I've experienced where the keyboard essentially reversed itself. All notes would immediately behave as if Hold was engaged and they would stop when a key was pressed like a brake pedal.
« Reply #3 on: May 16, 2021, 12:29:22 PM »
I had that happen on my first unit that was sent back, but I haven't had it on my new one.
« Reply #4 on: June 30, 2021, 01:40:46 PM »
Same here since my PRO3 arrived one year ago: After some few notes played, the keyboard reverses the action: Key down sends a release, key up sends a note.
I wasn't really ready to send the unit back for repair, since a power off/on cycle works and I was confident that it is just a firmware issue. Now, after reading this, it seems that I got another broken unit. How sad.
Pym
  • 201
« Reply #5 on: July 01, 2021, 04:36:28 PM »
Make sure you're updated to the latest OS version, that bug has been fixed
Sequential
« Reply #6 on: July 02, 2021, 03:37:54 AM »
Thanks for your reply, but I already have 1.1.2.8 running here.
« Reply #7 on: July 08, 2021, 11:24:54 AM »
I don't know how this can be, but since a few days, the PRO3 runs flawlessly. Operation time about 15-16 hours now without any issues, so I keep my fingers crossed that this has actually been fixed. Thank you once more!
Pym
  • 201
« Reply #8 on: July 08, 2021, 03:08:57 PM »
It will definitely be in the release tomorrow. Finishing it up now!
Sequential
« Reply #9 on: July 09, 2021, 04:23:08 AM »
Fantastic!
