My Prophet X 61 has worked flawlessly for three years and I’m on the latest OS. Last night out of the blue it inexplicably got stuck at the boot screen (bar full).
I had a look around this forum to discover that this is apparently quite an ongoing issue with a lot of Prophet X customers… and now me too :/
I tried that external keyboard F1 key trick to no avail.
Then I read about the 4hr jumper switch/new battery swap and did that too …but no luck.
Hey, potentially stupid question here but when I read about it here in the forums, it wasn’t specified whether the synth should be turned ‘off’ or ‘on’ while the jumper sits in the ‘2/3 clear bios’ position. Yeah I get there’s a shock hazard but I have (very carefully) changed batteries on other synths to preserve saved settings/patches in the past. I just struggled to imagine what good that jumper could possibly be doing with the synth turned off and no power running thru it. In any case, to be safe (until I hear otherwise), mine sat turned ‘off’ for four hours with the jumper in the ‘clear’ position. Afterwards, and with a brand new battery, I still have the same problem.
I’ve started a formal ticket but didn’t hear anything today. I’m confident that sequential will answer at soon …they were super helpful when my Pro3SE had an issue a couple years back.
Meanwhile, anyone else got any ideas to get this supremely expensive ‘luxury synth’ operating as intended? Any other tricks that worked for you? Sounds like there are (unfortunately) a lot of us out there…
Thanks in advance.
