Hello -
So first thing to be clear about: I'm not sure in what way I would notice Q Compensation, but when I ran through settings based on what I believe it's supposed to do (keep low frequencies elevated when filter resonance is increased), I don't hear any differences at any setting.
Sounds identical, looks identical on graphs...
So here's the test I did.
Filter cutoff max, Resonance sweep, ENV at 0% First REV1/2 filter at Q comp of 1, then 8. Repeat with REV3 filter.
There will be 4 filter sweeps you hear.
Then I moved cutoff to 50%, same order.
Moved ENV amount to 100%, cutoff 0%, res sweeps, but only on the REV3 filter.
There are 2 filter sweeps you hear.
I don't hear any differences, but maybe what I'm testing you wouldn't hear the difference.
And yes, I have confirmed I'm on the latest Main and Panel OSes.
Of course - I could never tell the difference between REV 1/2 and 3 filters so... I dunno.
