Today I experience an issue where the XMod Filter Envelope response is laggy and inaccurate - most noticeably with the VCOI pitch mod engaged. I can move the knob in either + or - polarity and it doesn't modify the pitch right away but will after a second, then when I move it back to the indented center the pitch is still modified as if the knob hasn't been moved. If I keep keying a note after re-centering it, I can hear that it's slowly adjusting back to the 0 point, but it takes a few seconds. I've attempted the standard recalibration with no noticeable change.
has anyone else run into this issue? Running the new OS 1.6.6
