The mod wheel CC from the Moog Matriarch is also creating this same issue. It’s as if the MIDI CC the Matriarch is sending for the Aftertouch & Modwheel parameters, is causing the OB-6 to changing parameters in the Current program. If anybody can muster up any ideas I am available to run any tests. Thanks
*the OB-6 works just fine with my Launch25 midi keyboard.
**the Moog is spitting out unaccounted for MIDI data that I captured in Ableton - here are the midi channels it is sending data out on:
Channel Pressure
1 - Modulation
6 - Data Entry
9 - (Controller)
38 - Data Entry Fine
90 - (Controller)
102 - (Controller)
103 - (Controller)
