Ver: 1.1.4.5, brand new unit
When I load the basic patch and set cutoff to 0, there is still some high end noise coming through. Playing from middle C on the keyboard, that noise stays louder than the actual intended output until about a cutoff of 65.
Is this as designed or a flaw?
I have recalibrated several times, no change. I can still easily return to the seller and get a replacement if it is a flaw that requires service.
It makes it difficult to create really soft sounds, as that noise is always very audible unless i set the filter so open that it's not soft...
