Perhaps you could elaborate a bit about your recording setup. I myself am recording mainly synthesizers and samplers, so I record everything in stereo to a Linux system using Audacity for recording and Ardour for mixing and mastering. Home made samples and sometimes singing voice(s) I normally record in mono.
Thanks for such an in depth response, i record it into a Focusrite stereo DI,i just find things can get very cluttered very fast, and have a hard time getting really good clarity and controlling dynamics. I use drum samples, vocals and sometimes guitars. So far i have been recording some ideas from the Rev2, trying to get the best sound i can from the machine.
What kind of headphones / monitor speakers are you using? I find that when I create my own mix I need to listen to it on different speakers and headphones, I even use my crappy car speakers to test the mix when driving to and from work. I have learned that if it sounds defined and well balanced on my car speakers it sounds good on almost anything else, ha ha.
For generic recording and having overall fun during the sound design and composing process I mainly use my good old (very cheap) Sennheiser HD201s. The HD201s are very comfortable on my head
, not too sweaty and so on. They sound OK, not very good and are not neutral, but it works for me. If I am alone in the house, I also switch sometimes to my office room hi-fi and play what I have composed / designed over the speakers (Kef). My partner really doesn't like hearing my twiddling and experimenting, understandably of course.
After I have recorded the tracks into Audacity, I import the wav files and I start the mixing and mastering in Ardour using my Beyerdynamic DT990 Pro. This really makes a difference for the mixing as they are reasonably neutral and it gives me better resolution to adjust EQ and compression. After the mixing I tend to listen to the track over my Kef Crest floor standing speakers. By this time I will have adjusted the sound enough to create a first (draft) master and I create a master flac/mp3 (insane high quality) to take with me to work and for in the car.
Most of the time I don't like what I am hearing and there is something missing, or blurred or too screeching and I go either back to re-recording a track, adjusting the patch or sample, or in Ardour adjust the mix. I repeat this process over a period of a few weeks till I am happy. If I don't get a good result after a few takes, I just throw everything away and start again. But that doesn't happen very often.
My samples are a mix of free downloaded drum, choir, voice and bass samples, single cycle wave forms, my partner's singing voice recorded and home / nature recordings. It can be quite tricky to get those nicely fitting in the mix. My last recording of a baking tray, which I hit with a wooden and plastic spoon and record into Audacity, transferred to the Akai, doesn't seem to work in any mix. Though the baking tray sounds really great on it's own, ha ha ;-).
