programmed patch
programmed patch
« on: July 13, 2017, 11:18:41 AM »
I am not the best knob tweaker and a newbie, and I realize this is along shot, but I'm trying to get an original factory patch 53 "Pulse Mod I" from a SQ P600 to my new Prophet 6 (or something very similar). Anyone here done this or can I install the patch from the P600 to the P6 via Midi?
« Last Edit: July 13, 2017, 11:47:45 AM by b3bro »
Re: programmed patch
« Reply #1 on: July 14, 2017, 09:56:55 AM »
Maybe this helps…
« Reply #2 on: July 14, 2017, 12:07:09 PM »
Yes, I discovered that in my old P600 manual. It's a start. Thank you.
Maybe this helps…
magikroom
  • 113
  • www.geosynths.com
    • GEOSynths
« Reply #3 on: July 21, 2017, 01:23:38 AM »
Have you got an audio example of the Patch?
« Reply #4 on: August 06, 2017, 08:50:33 PM »
@B3bro - here's a whack at the P6 patch for you. Thanks for the intro to the P600 patch sheets.
This is a single patch. It loads to and will overwrite 053.
I haven't heard the original so who knows how close this really is, but you can tweak it from here. If you get it any closer it would be great to hear the results!
Syx - https://drive.google.com/open?id=0B8PzRBLiyugvQ0kySVYtWkdOWEk
Audio demo - https://drive.google.com/open?id=0B8PzRBLiyugvd2FtQnpXMDN3RDA
=J
« Last Edit: August 06, 2017, 08:58:01 PM by abstrx »
« Reply #5 on: August 06, 2017, 09:06:01 PM »
Adding link to the P600 manual. 100 patch sheets start at pg. 51.
http://www.cyborgstudio.com/synthmp3s/sequential/prophet600/manual/prophet600operationmanual.pdf
« Reply #6 on: August 07, 2017, 10:04:38 AM »
b3bro, here's an updated version of the same P600 patch. it still loads to 053 but has some Juno-ish chorus parameters saved and a few other minor adjustments.
To play with and try to get closer to your desired sound:
- first compare with Sync on or off
- compare with Fx on or off
- try adding a little MW, like 10-20%. The P600 sheet shows LFO @ 75% but I chose to dial it back some and control from the MW.
- try minor filter cuttoff variations (key velocity will also change cuttoff)
- experiment with balancing the levels of OSC 1 and 2
- experiment with minor changes to pulsewidth for OSC 1 and 2 (best done when Sync is off and the other OSC is at a lower level so you can hear your changes)
.syx loads to P6 patch 053 -- https://drive.google.com/open?id=0B8PzRBLiyugvRGhLVk5VTWQ2eW8
mp3 demo -- https://drive.google.com/open?id=0B8PzRBLiyugvV2lxWGhoSmVMU0E
:j
« Last Edit: August 07, 2017, 10:18:15 AM by abstrx »
« Reply #7 on: August 07, 2017, 10:36:44 AM »
attaching .syx of ver 2
:j
