Global MIDI Trans, Recv and CC's
« on: January 30, 2017, 02:45:20 PM »
Prophet 6 w/1.3.1 Firmware
When Local Control=OFF, Not all parameters are handled when Transmit and Receive is in CC mode (works fine in NRPN mode which is also the default mode).
For example, LFO Modulation rate/level etc does not respond to changes, slop does not respond either. Effects on/off nothing.
Am I overlooking something in in the manual?
Do all parameters receive over MIDI when CC is enabled for transmit/receive?
Thank you.
« Last Edit: January 30, 2017, 02:57:35 PM by pmanderson »
Re: Global MIDI Trans, Recv and CC's
« Reply #1 on: February 02, 2017, 03:14:43 PM »
FYI
I found out; it turns out not all parameters are handled over CC.
