Ok I'm having a strange issue related to the sustain pedal and Poly Chain. When the sustain pedal is plugged into the Prophet 08' Keyboard and the Tetra plays a note, the note gets stuck on stays on. Depressing the sustain pedal (or sending an all notes off command) stops the note, but the next note that plays on the Tetra does the same.
It's happened with 3 different pedals. It happens with nothing else connected to the midi ports, not using a DAW. Just to make sure it wasn’t a bad port on the 08', I connected a Novation SL49 MK2 to my midi set up and plugged the pedal into the SL and triggered the 08' from it - same issue.
The odd this is that turning off (unplugging) and then turning back on the Tetra while the 08’ stays on seems to keep this from happening.
Anyone else have issues like this?
