OBX8 Knobs replacement
« on: April 24, 2024, 04:28:12 PM »
Hi there,
I recently bought an OBX8 module. I couldn't be more happy  :)
I was thinking about buying a blue overlay set wich has the Panel B functions printed on it. So only or aesthetical purposes i thought about changing the knobs too (that honestly don't feel that good).
I tried out with some knobs from other gear that i have but almost none fits the obx8.
Anyone could help to figure out what size/tipe of knobs would fit??
Any help is really appreciated !!
Re: OBX8 Knobs replacement
« Reply #1 on: April 24, 2024, 07:15:42 PM »
Hi there,
They're made by Elma and they are near impossible to find in low quantity.  The ones on the OBX8 are made for D-shafts, you would have to get the engineering drawing for the knobs for the dimensions of the D-shaped fitting then find a knob with the same dimensions.  Good luck.
Elric
  • 182
  • Peak Oil
« Reply #2 on: April 24, 2024, 10:29:58 PM »
My old oven dials fit my Pro3!
:Elric:
« Reply #3 on: April 25, 2024, 01:08:17 AM »
3D printing, if you’ve access, would make the trick
« Reply #4 on: April 28, 2024, 04:41:50 PM »
I sent an email to oberheim support asking for the knobs measures, here it is the answer:
“The pot diameter is ~6.02mm with a 25mm shaft and 7mm bushing.”
So if anyone out there is thinking about changing the knobs on the OBX8 dekstop version, those are the exact measures.
