To test if pedal works do like this
- see to that global setting Foot pedal is Volume
Then any preset you play will give volume same as if using master volume knob
- I doubt that little popout is vital, there are different tolerances on plugs
Then you know pedal works as such
- Not sure if Moog pedal is working, Boss EV-5 compatible though works
- Korg and Yamaha pedals as I recall have different tip/ring reversed
Then change global setting to CC11
Then changing first modulation slot in F1 P25 does not make much audible difference
- just filter decay
Change all slots that have ModWheel as source to Expressn
- then to also have vibrato from wheel transferred to pedal you have to use another free slot
- so set source to Expressn, dest to lfo4 and value -5 as on the mod wheel
It works fine by me anyway.
- but I have an EHX expression pedal that I can swap tip/ring behavior if I want
- now it is set same as EV-5 type
- so first test with volume will tell
Good luck and Happy Easter!
