The headphones socket on my Rev2 is reversed in that any panning to left or right is reversed. What is even worse, my Layer B outputs are also reversed. Layer A outputs are correct. I know it is just a simple case of swapping the audio cables to my mixer or audio interface but it can be very annoying!
Does anyone know if I can simply open the Rev2 up and somehow swap the Layer B outputs around? I guess the headphones would just need the wires reversed with a bit of solder work.
Any thoughts or help? Has anyone else come across this problem and what were your remedial actions? Thanking you.
