Hi I have recorded two different patterns in layer a and layer b. to get them to play at the same time I have to start a then hit EDIT LAYER B then hit PLAY again. is there anyway to get them to start together?
Thanks
Yeah, to re-sync the two sequencers to Step 1, you have a few choices:
1. Resave the patch (Press WRITE twice)
2. Turn off and back on again the stack or split (Press STACK twice)
3. Navigate to next patch then back to intended patch (Turn patch or bank knob forward one step then back)
I usually use that #2 method of just quickly turning off and back on again the stack, to reset the phase of both seqs.
