Sure I don't mind sharing at all!
The wavetables are from stock Serum, the juno106 wavetable + 5 additional tables I messed with (took the last wave and made 5 copies, then mucked about with them)
Dragged them into audacity (44khz 16bit, 2048) then converted to 96khz (hit the down arrow on the file, then rate => 96khz) then switched project rate to 48khz, and exported.
Checked via dragging them back into audacity, and sure enough, they are 48khz , 16bit, 1024.
Created the sysex file, and exported to the pro3
Let me know what the results are!
*** Update ***
Ok I also just realized, that during my A & B testing of the waves loaded into the pro3, I was testing them against the serum waves which were un-processed...so they hadn't had the morph tables removed (not that there are any in the juno106 wavetable in serum) , nor had I done the "fade edges -> gird size" command. Upon doing this command, I can see it does modify the tables substantially. Upon testing the pro3 against the waves which the fade edges command completed, they do sound quite close. Still slight duller, but much closer.
***2nd Update***
Re-did the wavetables from serum WITHOUT using the fade edges, and they still sound great! and VERY close to the serum wavetables. I'm thinking that the dullness could just be because they are now going through an analog filter? Either way, much happier with the results now. Going to not bother with fading the edges anymore, as it changes the wave too much, and it doesn't seem to be necessary!
I included the sysex for the juno without the faded edges as well (real_Juno) for people to have. Waves 11-16 are just my modified waves of the wave in position 11
