So no one can chime in?
Is the Beat Sync what replaces the old school standard midi clock tempo sync(apologies if I am not using the correct verbiage)?
Let me set up my SQ-80 (enhanced ESQ-1) and see what I can come up with...
Okay, it's working fine here. But I had to change the MIDI Clock parameter in the OB6 module from OUT to IN (hit Globals once and 3, change it using the two SELECT buttons and then hit Globals two times to get out).
BTW, I found a software bug doing that because the OB6 cannot display BPM below 30 (the Ensoniq goes down to 25 BPM), and the display is flickering with a minus sign... But it still works. Only the CLOCK display number is affected.
