Thanks it’s my first keyboard and i just started to get into it and started to save some patches but just wanted to reset it back. I notice if I press the global button it goes to red while I press the write button and nothing seems to happen. Am I doing this right?
Thanks
Resetting the Global Parameters is NOT the same thing as resetting all the sounds. That's perhaps why you concluded that 'nothing seems to happen.' Doing that would have reset the Pitch Bend range, or Global Tuning to their original factory values, for example, if you had altered them (and saved the alteration by Saving Globals) -
What you seem to want to do is remove the saved Program edits (changes) you have made. There's not much reason to do this, since every user-savable sound is duplicated at a memory location 500 higher than the one you edited and (may have) saved.
For example, say you liked 007 (I love it!) and turned the Filter Cutoff knob clockwise a bit, and liked it, so you hit WRITE and then pressed the 7, so the WRITE light went out. Now when you call up 007, it will be your new sound. But maybe you miss the way it used to sound. You don't have to reset anything in this case! Just go to sound 507, and the original sound that was in 007 is right there! And the '500' sound can't ever be changed. It'll always be there, because it's not in "User Memory" - User Memory is the numbers below 500.
If that's not quite good enough, and you really want the original James Bond (007)
in its original 007 location, you can go to 507, then hit WRITE and then hold the Bank Button and Press 0...then press the 7 button, and now 507 has been stored to 007. Remember 507 is exactly the sound that was originally Factory in 007, so you have accomplished your goal, without resetting and other sounds of which you may prefer your new (edited and Saved) version to the Factory version.
