Toggle navigation
Home
Help
Search
Login
Register
Login
Register
Close
Login
Remember me
SEQUENTIAL/DSI
Evolver
(Moderator:
Poly mode playing 3 voices from single key press?
Print
Pages: [
1
Orlog24
4
on:
August 11, 2018, 05:35:52 PM »
Basically, 3 voices play when I’m playing one note. Anyone else experience this?
Is it a setting I don’t know about?
Ed
Logged
Re: Poly mode playing 3 voices from single key press?
Reply #1 on:
August 11, 2018, 07:07:06 PM »
Go into Global, scroll to page 2, and set the voices for the total number you'll be using (if you're poly chaining.) Otherwise, set it to "Off."
Logged
Orlog24
4
Reply #2 on:
August 11, 2018, 07:43:49 PM »
It is set to off.
Now it is playing 2 notes for one key press btw!
Can deoxit be causing it?
Logged
Reply #3 on:
August 11, 2018, 08:16:05 PM »
Well, at least that's a little progress!
So, you used deoxit to clean the parameter housings? If so, perhaps you need to work each parameter for a while - meaning, rotate it many times to work in the deoxit.
Logged
Orlog24
4
Re: Poly mode playing 3 voices from single key press? Solved
Reply #4 on:
August 12, 2018, 06:32:49 AM »
It was a MIDI loop going on.
Logged
Reply #5 on:
August 12, 2018, 07:57:20 AM »
Glad you figured it out.
Rule #1: When you're having a technical problem with an instrument, unplug everything before going another step.
Last Edit: August 12, 2018, 08:30:16 AM by Sacred Synthesis
Logged
Print
Pages: [
1
SEQUENTIAL/DSI
Evolver
(Moderator:
