Heya,
I had my Prophet Rev2 hooked up to my DAW through USB - parameter receive off it simply played patterns.
After a while and no change to this configuration it only plays keys with regular intervals like there's a magical gate controlling my input through keys.
I disconnected my Prophet from everything (incl. power) reset global settings.
The same problem occurs on output A and headphones.
The same problem occurs on all patches.
The same problem occurs on Basic Program.
The same problem occurs with the same interval when I change the BPM and divide rate (so though it's with a regular interval the internal clock doesn't seem to have a relation to the issue.)
I am honestly pretty freaking bummed out right now. Like really badly. Pls help <3
I am going to update the firmware to it's latest version after posting this and see what happens.
I could add a video in order to show the issue a little better if needed.
Edit: Updating the firmware had no effect.
Regards,
Ron Dgasz
