REV 2 stopping playing midi in Logic...helllllllllp!!!
S Y Z Y G Y X
  • 162
  • WWW.SYZYGYXMUSIC.COM
    • S Y Z Y G Y X
« on: March 01, 2018, 08:43:50 PM »
So I’ve had the most frustrating day trying to get my Rev 2 to stop bugging out.  It records midi into logic fine and even plays the midi back fine but it eventually after a few minutes will either get stuck on a note OR it will just stop playing the midi notes in logic and I will have to turn off the Rev 2 to get it to work again.  This is so frustrating, I have a 4 other hardware synths that do not present any problems like this so I know it’s not my midi settings in Logic.  I have local control set to off on the Rev 2.  Has anyone encountered these issues?  Any tips on any settings in either Logic or the Rev 2 that I must adjust?  Please I’m dying for help or answers as I would rather not return this synth but if it keeps acting up like this I’ll have no choice  :(
www.syzygyxmusic.com
https://syzygy-x.bandcamp.com
Re: REV 2 stopping playing midi in Logic...helllllllllp!!!
« Reply #1 on: March 01, 2018, 10:01:57 PM »
I can only strongly suggest that you contact the excellent DSI support team via email. They're usually very quick to respond.
« Reply #2 on: March 02, 2018, 12:47:03 AM »
Are you using USB or Midi connection? I had a similar issue using Studio One while using USB, but it worked fine when I used midi. I haven't tried it lately with USB, but I assume I would get the same results.  I reached out to tech support and they had me try a few things and still couldn't get it resolved.
S Y Z Y G Y X
  • 162
    • S Y Z Y G Y X
« Reply #3 on: March 02, 2018, 06:40:37 AM »
Ughhh, yes i called over to DSI yesterday and I was suggested to disable soft midi thru in Logic but I’ve been all over logics settings and it’s not logic as I said I have other hardware synths which operate just fine.  I will call again today and hopefully speak to Carson about this issue.
I will lose midi signal or a note will get stuck especially as I am turning the filter cutoff knob....
« Reply #4 on: March 02, 2018, 03:26:09 PM »
Same thing with my synths. It only happens with the REV 2. I couldn't figure out which knob would make my notes get stuck.  If I just let the recording playback by itself looped it'll take awhile to stick, but turning a knob would makd it get stuck quicker.
S Y Z Y G Y X
  • 162
    • S Y Z Y G Y X
« Reply #5 on: March 02, 2018, 09:06:39 PM »
Jigaggod ...wow you were right on the money homie!!!  I tried so many more hours on my day off today trying to sort this issue out with Carson and Andy...solid dudes BTW....to no avail....so luckily i ended up having a MOTU midi interface lying around and boom!  I set the Rev2 up vía midi cables to the MOTU and looky here...everything now works FABULOUSLY...no more issues!  Thank god for the midi interface!!
« Reply #6 on: March 03, 2018, 03:31:06 AM »
Good to hear you get your problem solved!
« Reply #7 on: March 03, 2018, 08:56:31 AM »
Good to hear it's work for you.  I still wish they would fix the USB issue whatever it. midi is a bit slow with changing patches
S Y Z Y G Y X
  • 162
    • S Y Z Y G Y X
« Reply #8 on: March 03, 2018, 10:57:31 AM »
I am relieved that i found a fix as I was about an hour away of returning the Rev2 to Sweetwater to exchange it for a Prologue.  The Prologue sounds sweet but I went with the Rev2 because of its many mod slots, LFOs, and aftertouch.  I can’t believe Korg would make it’s flagship synth with only 1 LFO, no mod matrix and no aftertouch....
What do you mean when you say Midi is a bit slow with changing patches?
« Reply #9 on: March 03, 2018, 04:37:26 PM »
That it takes like a second longer to switch to the next patch if you're scrolling through sounds. Its not a huge issue. Just noticeable when I switch from USB to Midi.
