No, it’s a good learning point for others, we’ve all been there I’m sure!
True enough.
If anyone are playing their keyboards and for some reason when you hit the key and it doesn’t make sound , Here are some things to check before you make an embarrassing post, thinking your prophet is broken
1 global setting velocity - make sure it’s adjusted to the max OR to your liking
2. Keymode - you may think you’re not getting sound but it may simply be due to keymode configuration so check keymode to ensure which notes get priority
3. Firmware upgrades or not realizing you’re playing more than 6 notes . Would personally check this last
4. Program you’ve designed or playing hasn’t been set up in a way to have this result . Basically double check on and blank preset
