I've run into a problem...
I have my REV2 connected to my computer via MIDI I/O, and my sequencer is set to echo the REV2 MIDI data back to it... a very standard way of using MIDI gear with a sequencer... I also have the REV2's "Local Off" set to "off", so that I do not get doublenotes etc.
But with this configuration, I cannot record poly sequences... as soon as I press the "RECORD" button on the REV2, the REV2 sends out an NRPN command (that I do not know what is by the way). this is of course echoed by my sequencer, and when the REV2 recieves it again, it sends it out again, resulting en and endless MIDI loop.
So basically, I'm unable to record poly sequences in this setup... I've sent DSI a bug report...
