Is it just me..?
If I set the MIDI clock mode to Off and set the tempo locally (120 BPM default) and create a patch with the sequencer, clock-synced LFOs etc., all works fine.
However, I discovered that when I set the Rev2's MIDI clock mode to one of the Slave modes and have my DAW (Sonar X3) transmit the MIDI clock (also set to 120 BPM), the Rev2 runs everything at half speed.
The same experiment with my Roland JV-2080 produces identical timing using either its internal clock or the one from Sonar, so Sonar and the JV-2080 agree.
I bypassed the PC completely, connecting the MIDI output from a Roland TR-09 directly to the Rev2 (all DIN, no USB connections used). This did the same as with Sonar. For the same BPM, the sequencer on divide by 16 with the Rev2's internal clock needs to be set to divide by 32 to run at the same rate.
Is this by design, a bug or have I missed a setting somewhere?
