Is it possible to split the MIDI out signal of the rev2, so that only one side of the keyboard is sending MIDI out? I was hoping to be able to simultaneously use my rev2 as a controller and a synth.
Hi jburzy01. I'm finding your inquiry a bit vague. If you provide a more in-depth description of what you are trying to achieve--as in x piece of gear controlling y piece of gear, etc.--perhaps we can better offer suggestions.
As Bezoblika points out, with Multi Mode enabled along with Split, the keyboard will transmit MIDI note data independently on consecutive MIDI channels on either side of the split point. If you set the B layer Program Volume to zero, the B layer patch will not sound when you play the keyboard above the split point, and you could thus control another piece of gear in this manner with the synth only making sound from the A Layer when you play below the split point. This does mean that you would only have access to 1/2 of the voices in your Prophet Rev2, but it is achievable.
One thing to keep in mind as you're configuring your setup is that, while our instruments feature robust MIDI implementations, they are not designed to double as full fledged MIDI controllers, and thus will not have the flexibility of a dedicated controller keyboard in this regard. We design our UIs to serve the purpose of the instrument first and foremost, and aren't interested in compromising on this front in order to serve a purpose for which they are not intended. A dedicated MIDI controller keyboard will make a better MIDI controller than one of our instruments in most situations.
