Hey Guys,
Firstly Merry Synthmas to everyone, hope the food, drink and cheer is going down well.
Apologies if you see this on multiple sites, It's cross posted to the usual places.
So I've been making use of the time off of work to finally get all my studio re-cabled after relocating some months ago. Everything has been going great until I switched on my OB-6.
I'm getting a horrendous electrical hum from the outputs, like a bad earth somewhere. I'm not skilled enough to fix it, and I'm hoping someone might have some ideas as to what could be wrong. My gut feeling is it's an electrical ground somewhere, but it doesn't make any sense. Before I re-cabled and re-patched, the OB-6 was working perfectly, and along with the Prophet~6 is my favourite pair of poly synths, which makes this issue all the more painful for me... and on Christmas day as well.
So here's the rundown of connectivity:
OB-6 plugged into my 01V96i directly into channels 1 & 2 (L & R) - Cables are homemade Gotham 2 core, with a Neutrik NP2x on the synth output end, and an NP3X on the balanced input end that plugs into the mixer. The input level has always been padded by -20Db. These cables are made based on the Rane recommendation, and have previously been working fine, and I have lots of the same config of cable for the rest of my gear that has unbalanced outputs. So these are a TS > TRS cable. - The hum is there when connected like this.
Here's what makes me think there is a ground fault...
If I run a wire (and in this case another audio cable,) and bridge the outer shell of the Neutrik plug that is connected to the output of the OB, to one of the screws on the chassis of the 01V, the hum is GONE, and the output signal is normal.
If I plug in a balanced cable, so a TRS > TRS lead from the OB to the 01, the hum is gone, BUT, the output signal is much lower, and I have to un-pad the input.
So the Prophet~6 is working perfectly with no issue, using the same power and output cables. If it was a power cable, or earthing point issue, I'd expect the behaviour to be reproducible on the P~6.
So it's got to be the OB right?
Something weirder.. I've got an old Technics DJ mixer which I dug out just to test with. It DOESN'T HAVE any earth to the mains, it's just one of those figure of 8 power cables that are Positive/Neutral. If I plug the OB into one of the inputs using a TS to RCA cable, there is no hum or hiss or anything, the OB works perfectly.
Can anyone with some electronic/electrical experience give me any pointers?
Thanks
