Back to do some more analysis here. For this post, I am comparing the use of two oscillators in the P-12, P-08 and as an analog baseline - the KARP Odyssey. In each case, I again used the saw tooth wave for comparison both tuned to the same note. The low pass filter was wide open on each synth. So, all the harmonics were coming through. The second filter on the P-12 was not engaged.
As I'm sure many of you are aware, putting two oscillators together, in tune, does not have an additive effect. There is actually cancellation of harmonics. It's when they are placed somewhat out of tune with each other that all the magic happens.
In this first recording, I started with a single oscillator and slowly turned up the volume on the second. As the volume increases of the second oscillator, the harmonics cancellation can be heard. In this first recording, the synths, in order are the P-12, P-08 and Odyssey. The P-12's cancellation occurred mainly in the mid range. Some mid-high and low frequencies start being accented as the volume of the second oscillator increases. With the P-08, the harmonic cancellation is more consistent across the spectrum. The overall effect is the volume reducing as the second oscillator is dialed in. The Odyssey, I was not able to get perfect tuning (after all, it's a VCO
). When the volume of the second oscillator is increased, there is cancellation, but there is some phasing since the oscillators are not perfectly aligned.
https://soundcloud.com/jdt9517/2017-01-13-p12-2-oscs-comparedNext, I detuned the oscillators slightly which is the base for many of the classic analog sounds. I started with the Odyssey, using a slight detuning that I typically used in programming analog synths in the past. That "classic" sound dialed right in. I used approximately the same detunings on the P-12 and P-08 using no slop to compare. I was amazed how close the P-12 got to the classic sound with the minor detuning. The P-08 is the last sound on this second recording. I was amazed how un-analog it sounded. The classic phasing was not there. While I did not record it, I had to use much more detuning to approach the classic sound.
What this tells me is that I can use a more traditional approach with the P-12 to get the classic analog sounds. The P-08 will require more detuning or slop to get there. While I was not really aware of this, I looked back on some of the programs I have done on the P-08 and found that the detuning was more extreme than I probably would have used on say the P-05.
https://soundcloud.com/jdt9517/2017-01-13-p12-2-ocs-detuned
