I've been really enjoying the sequencer on the Pro 2. Unfortunately when I control external gear via tracks 2-16, the timing gets interrupted and hiccups when I make almost any parameter change on the Pro 2. It does this even when I have the MIDI Out channel set to a channel the external gear is not using. If I disable the the "Paramater Transmit NRPN" function, then I can turn knobs and the interruption is gone...but it still gets interrupted with any note played on the keyboard. This occurs even when the sequencer play mode is set to the sequencer and if reset is turned off.
On a related note, I also find the way the arpeggiator and sequencer reset very difficult to play - it would be more useful if it was quantized to the nearest 16th (or perhaps whatever value the sequencer is running at).
Is there something funky about my setup?
