horsing around with the TEO-5 poly sequencer
« on: July 25, 2026, 08:32:38 AM »
TEO5 These Eyes.syx - sustained notes + chords  :)
Created on OS 1.2.0.15, guessing it will sound the same on older release OS - like to know if that’s not the case
attaching an edit buffer dump (so it won’t replace one of the saved user programs when sent to the synth)
Re: horsing around with the TEO-5 poly sequencer
« Reply #1 on: August 08, 2026, 07:20:27 AM »
(btw  the last one was 98% factory program Reed Between, just with different effect and sequence)
Here’s another, adding sustained notes and replacing some notes as it goes. Tried Note Reset on LFO2 to get it to behave like a ramp which begins at the start of the sequence, but playing the sequence multiple times in a row, seems it does not always reset at the beginning.
