Van Halen Jump sound
Started by markc2, June 16, 2026, 08:00:44 PM
0 Replies 9,205 Views
markc2
Commerce
after spending a bit of time with this, I found that if you use the U96 which I am guessing is F96, it's called Eternal, it's a beautiful pad. sweetish. You can modify the DADSR amplifier envelope and get super close to the Jump sound Then you can add chorus, and tweak the cutoff and the resonance very gently you get even closer, and then if you stack the sound, you can add reverb on the 2nd layer while keeping the chorus with the first layer. With the stacked sound you have to make the same type of changes to the DAADSR again, but man you use the octave +1 it's Jump, if you put it back down to 0 it makes a very hefty synth for Subdivisions.
What I've been finding is if I can find a really sweet pad it's so much easier to make that sound. Did it on the Polybrute to wonderous effect.
Saw  :-) this mentioned in what I think was this forum but I didn't know how to do a search.
