Do You Use Poly Unison And Stacks And Splits Often With The P10Rev4
I’m not currently using these capabilities with my P10 Rev4 . Not sure exactly on how to implement them. Thanks 🙏
g3o2
  • 179
Re: Do You Use Poly Unison And Stacks And Splits Often With The P10Rev4
« Reply #1 on: April 09, 2026, 12:39:44 AM »
Poly unison is comparable to the binaural mode in ob-x8, minus one ear.
The other two are similar to x8's equivalents, with x8 having the direct UI advantage.
« Last Edit: April 09, 2026, 12:41:25 AM by g3o2 »
« Reply #2 on: April 09, 2026, 12:46:13 AM »
I See
558
  • 111
« Reply #3 on: April 10, 2026, 11:41:21 AM »
For the PU You hold UNISON button and go the up or down arrows (left of the red digital watch display) up for PU and down for other things such as Monophonic (when Unison gets down to the bottom *L direction it is at 1)  Up or down.  Simple.  You will want to also use the button for Keyboard and the up or down to select whether you are using Lo only, Lo retrig, Last only or Last retrig.  Listen closely and play around you will hear the difference.
Another satisfied Prophet 10 owner
« Reply #4 on: April 11, 2026, 07:40:50 PM »
Thanks Appreciate It.
« Reply #5 on: April 12, 2026, 01:44:55 AM »
I have used it some but not very much. My intension is to make more dual layer patches to use.
« Reply #6 on: April 12, 2026, 10:21:46 AM »
Right I See
558
  • 111
« Reply #7 on: April 17, 2026, 08:55:57 AM »
It's pretty tricky making split patches.  I have some banks saved that can bring up a split patch.  If you save one of the layers of the split in the same bank as the other layer that is the A portion, then you can reload that bank and mark it in your files as a bank that has a split or splits in it, and get the same sound because both layers are in the bank.
So you go UNI + ^ and it takes you to split, and then you select the layer you want to be operating on.  Then when you save it, A goes to the button you save it to, but the B portion is someplace else.  Typically you surf to the B program you want while it is set to change B, then you select that and it becomes the program for B.
If you work on your b portion, actually it may be that you must save it to a separate button.  Best to test that part first, and make sure what you save is what you were working towards in the B layer.  When you go back to the split button and bring it back you will hear the same A layer but the B will still be pointed to the original program that B was.  So you may need to change it to the newly saved button see?  So best to save it into the same Bank if possible.  It's pretty fundamentally difficult to conceptualize how to save your changes.  So save the B first (if you changed it) to another program in the same bank, that's how it works best.
I may have misspoken about this so don't quote me.  But the B portion MUST BE SAVED separately.  I am not at all sure if it won't be saved as a split.  It's tricky.
« Last Edit: April 17, 2026, 09:05:15 AM by 558 »
