Can confirm like other said that removing each voice card, dusting them and the holders, and then putting them back solved all my tuning and calibration issues!
Before I used to get one of the voice sound always weird until I recalibrated it. Then the calibration started to hang at 11..now everything looks and sounds good!
Instructions for the desktop version:
1) Remove the screws on the sides (there are two on the wood panel and two behind it) and from the back - total of 12 screws.
2) At this point you should be able to lift the front panel and gently rotate it away from you so that the panel can rest behind the synth body.
3) you will see 6 cards with two visible condensers on each sticking out towards you, and on each side of each voice card there are two white clips you need to press together in order for the card to pop out.
4) once it is out, shoot it it with compressed air and do the same for the holder.
5) putting them back is the trickiest part: In my experience is good to push first one side in a little from the corner, then do the same on the other corner and repeat until the clips can be closed back. Push them a little more and try to apply a perpendicular force, no twists to avoid breaking the PCB plastic - look at the other cards to know what orientation the one you are putting back should have..they look like they could fit both ways.
6) repeat for all the voice cards
Good luck my friend reading this, hope it solves your issues!
