Filter knob usable range
« on: April 05, 2026, 04:06:53 PM »
New to the forum—hi everyone!
I just got a new Pro 3 SE. Overall it's working well, but I did notice one weird issue, and I'm wondering whether it's normal. When I turn the filter knob (in "Jump" mode), the value shown on the screen reaches zero a little to the right of 9 o'clock, and turning it to the left of that has no effect. If I set the pot mode to "Relative," nothing happens when I move the knob within that range. I tried this with nothing connected to USB or MIDI, so it's not a MIDI loop.
This doesn't really affect the functionality of the synth, but it does mean that about 1/5 of the travel range of the knob is useless. Has anyone else encountered this? Is there some way to recalibrate the pot?
Re: Filter knob usable range
« Reply #1 on: April 07, 2026, 12:16:02 AM »
There is a calibrate option in the settings, not sure if it does what you suggest though. Try this, initialise a patch, you can do this with key combo I never remember or there’s initialise patch in the settings menu. Select saw wave, fully turn the filter between clockwise and anti-clockwise. Also, try the different catch up settings. I’ll try my unit later to see if it mirrors what you reported above but from memory, I don’t think it’s the case.
« Reply #2 on: April 08, 2026, 01:52:23 PM »
Thanks your reply! By "catch up settings," do you mean the different "pot modes," like jump and passthru? I did try all three of these, and I still have the same issue with the lower 1/5 of the pot having no effect no matter how it's set.
I ran both of the calibration procedures in the menu, and they didn't help. It seems like I need to do something similar to the wheel calibration procedure, but for the filter pot.
BT
  • 125
« Reply #3 on: April 08, 2026, 02:48:58 PM »
Hi there! There are dead bands at the lowest and highest physical ranges of the high-resolution cutoff pot. If, while on the basic program, you can use the pot to drop OTA filter cutoff to 0 and effectively cut off all sound, then your pot is functioning as expected. Apologies for any confusion.
« Reply #4 on: April 09, 2026, 07:46:08 AM »
Thanks! It's reassuring to hear that it's normal. It is annoying because the dead band is much wider than I've experienced on other synths and covers a significant portion of the knob's travel. But I am able to close and open the filters fully, so it's not really a functional problem.
It's a great synth overall. Though I do have to resist the temptation to crank up the distortion on everything, ha ha!
