Prophet 5/10 Rev4 Aftertouch
Started by seqpro3, April 04, 2026, 06:22:45 PM
4 Replies 16,593 Views
seqpro3
Jr. Member
Those of you that have the P5/10 Rev4. Do you think its aftertouch takes a strong press to  get the aftertouch to activate. How do you adjust the aftertouch curve in regards to its sensitivity? I know on the OX8 you can adjust the aftertouch curve  sensitivity in the Global Settings. Wasn't sure how to do it on the P10/Rev4. Thanks 🙏 I googled it and tried with the instructions it gave although I couldn't
change the aftertouch curve sensitivity. Thanks 🙏
HockeBocke
Jr. Member
#1
Main 2.0.4 - Adjustable Velocity/Aftertouch feature use instructions.
1. Hold VELOCITY or AFTERTOUCH button.
2. Use INC/DEC to set the amount of VELOCITY or AFTERTOUCH modulation to be applied.
3. The setting affects both modulation destinations for velocity or aftertouch and can be saved per program.
Suggestion :
Check out the handy "Cheat sheet" from this "Propheteer" :
https://forum.sequential.com/index.php/topic,8526.msg71196.html#msg71196
Cheers !
1976 MiniKORG700s // 1979 Prophet-5 rev.2 // 1981 KORG CX-3 // 1984 DX7 // 2020 Prophet-10 rev.4 // MoPho Box // 2 Creamware MiniMax // Creamware Pro-12 // 2 EMU-Proteus 2000 // EMU-Vintage Keys  // Casio VZ-10M // Roland VK-8M // Fatar SL 880 // Roland JUPITER-X // KORG CX-3 V2 //
seqpro3
Jr. Member
Quote from: HockeBocke on April 05, 2026, 05:41:51 AM
Suggestion :
Cheers ! Thanks 🙏
Quatschmacher
Full Member
Suggestion :
Cheers !
That sets the depth as opposed to the curve.
The curve is adjusted via the global menu, though they are just different setups so you just need to play through them and see which suits you best.
seqpro3
Jr. Member
Quote from: Quatschmacher on April 05, 2026, 10:58:23 AM
Suggestion :
Cheers !
I see thanks for the information.
