Difficulties using MIDI-OX to update the Fourm [alternative solution provided]
Started by PhrygianPhrog, March 22, 2026, 03:01:24 AM
2 Replies 18,603 Views
PhrygianPhrog
Commerce
I'm making this post in case it helps others who are having trouble sending Sysex data to the Fourm using MIDI-OX.
I spent a few hours without success yesterday trying the update on Windows 11. I tried via both MIDI and USB, using different computers, various buffer num/sizes, but every time it threw the "SysEx: No Buffers Available" error. I also made sure (as best I could anyway) there was no software running that might be locking the USB interface/port.
I tried searching for other Sysex tools using Google and AI, but none of them worked and lacked lacked features to troubleshoot the issue.
Then I found Bome Send SX, a free tool, which worked perfectly and was able to update both the firmware and add the extra preset banks easily. This tool was not returned in my Google/AI searches, hence I am posting here (I have no connection to the developer).
https://www.bome.com/products/sendsx?fbclid=IwY2xjawQsmGJleHRuA2FlbQIxMABicmlkETFGdVFWZGkydFM0MjlhMUREc3J0YwZhcHBfaWQQMjIyMDM5MTc4ODIwMDg5MgABHj_T3Be4rI7HDs8MzDU04vg5gEl7fyL1o8ypElmgoNoHlDPrk1DjiBQZ4zUc_aem_0ccTJbhwz6-GN0yLg6vhuw
Hope this helps! The Fourm is an amazing-sounding synth.
Jpro600k
Jr. Member
https://sequential.com/support/download/fourm-operating-system/
Windows instruction
Set the Low Level Output Buffers "Num" and "Size" to 1024.
Troubleshooting information can be found towards the bottom of the instructions page.
I usually back up my presets using MIDI-OX, and I've never had any problems, so maybe just adjusting the buffer value settings will solve the issue. Well, it would be great if it worked without any problems. Backing up all the presets takes a little time because there are so many of them. Back up only the user bank only uses half that number, 256 sounds.
Ah, but since it's an update, maybe something will be different. If there are any problems, I'll try it out.
Jpro600k
Jr. Member
SysEx_Transfer_Tool
This is a tool for transferring system exclusive files via your browser.
I've tested it with FOURM. Please give it a try!
Even after "Success All messages sent!" is displayed on the screen, the synthesizer may continue receiving data for a while, so please wait until the synthesizer's LCD returns to its normal state.
FOURM took a long time to process because it has a large number of presets, but it might be better to test with a file that has fewer presets.
Please download it and then open it in your browser to use it.
Chrome is recommended.
It uses a web browser but does not require a network connection. It works locally. There should be no problems. If you are worried, you can disconnect before using it.
