Pro 3 - Gated Sequencer triggered via MIDI issue
Started by stalfosia, March 17, 2026, 09:51:17 AM
1 Replies 18,243 Views
stalfosia
Commerce
Hello...  New Pro 3 SE here.
Question/issue with using gated sequencer.
I'm triggering via MIDI using an Elektron Digitone II.
(that's my brain for most hardware, atm)
I can sequence the PRO 3 just fine normally, one note at a time.
I can also sequence all my other external hardware just fine.
Things start to get unreliable when I use the gated sequencer, triggered by the Digitone.
I'd say 90% of the time it triggers as expected, but sometimes there's a "dropout" and no trigger happens.
That particular midi event is ignored or something.
Then it picks up again correctly on the next midi event.
Does this sound familiar to anyone else?
I'm using latest firmwares
Main_1.2.0.4
Panel_v1.1.0.13
Settings in Global are as expected, I think.
Clock Mode is set to "In No S/S", as I only want the sequencer to run when triggered.
Thanks for any insight here!  :)
- Justin
RadekPilich
Commerce
#1
Yes, I am misremembering, will detail it later.
I had some issue where it basically started two steps late, or is somehow out of sync....
.... if we sent a sustained note.... if we sent a series of short individual notes, it played as expected.
Sorry, later....
