As per the title. Am tearing my hair out over this. I can see it can be done via the synth itself, but can't find a way to do it in the Librarian? fish it!
Quote from: A-3440 on March 08, 2026, 04:05:03 PMAs per the title. Am tearing my hair out over this. I can see it can be done via the synth itself, but can't find a way to do it in the Librarian? fish it!I ran into something similar with the SoundTower editors before. In many of their Librarian versions, some parameters (especially layer-specific program names like Layer B) are not directly editable from the librarian interface. The software often lets you edit the main patch name, but layer names sometimes only update when they are changed on the hardware and then re-synced back to the computer.Which synth model are you using with the SoundTower Librarian?
… deleted quote …
I don't remember if you can the name of Layer B, but if you can't, you can still easilly swap layer A and B and then edit the new layer A name. Then swap A and B again if you want.
A-3440: That previous response was one of the spam posts that I referred to earlier. That sonadvan is likely just a bot; its response to you included a link to some other site probably as an attempt to increase SEO ratings on it or something. By quoting it, you propagated that link in your reply.
