I want to use decimal points for the BPM of the FOURM.
Started by Jpro600k, February 28, 2026, 06:51:38 AM
1 Replies 16,836 Views
Jpro600k
Jr. Member
This is because when creating at 127 BPM, you will use half the value, 63.5.
Please make it possible to increase or decrease in 0.1 increments.
It's musically necessary.
Jpro600k
Jr. Member
This is just an example. This is to record the arpeggiator in real time at half the BPM of the track. It's also effective for creating small rhythmic combinations in tracks. It's also effective for creating complex, detailed rhythmic combinations in my tracks.
ome division options don't provide a detailed number of divisions, and none of the available settings fit the rhythm. I would like to be able to use up to two decimal places if possible.
As the value gets more detailed, the number of times you have to turn the knob increases, so I would like to see the following process introduced: Press a button to select the number of digits to change the value by, and then turn the knob to change the value.
