Hello dear Oberheim team,
sorry to bother you again. But it seems to me that my TEO-5 unit has an issue with one voice, or more exactly the modulation routing to the oscillator levels of it.
I tried to create a patch where I use one of the envelopes to modulate the level of osc2 from 0 upwards, kind of fading osc2 into the patch, what worked pretty well - but it sounded non modulated every 5th note. First I calibrated the synth, but this did not help.
Then I did a little test on osc2 alone:
- Basic program
- Filter totally open
- only osc2 acitve (level initialy 0)
- env1 modulating osc2 level positve
The first 4 notes play like expected, getting modulated by the env, but the 5th stays silent. Time between notes doesn't matter as the 5th note also not plays after minutes of waiting. The problem also occurs on all osc (osc1, sub, osc2, noise), and with env1 and env2.
Therefore I guess my TEO has a defect in the routing of the 5th voice to the osc levels. Could you pls confirm that this is not a normal behavior or tell me where I'm understanding something wrong here.
With best regards
Oliver
