With an all-new 16-voice digital / analog hybrid synthesis engine, Leviasynthฎ takes a unique approach by providing 8 oscillators with over 300 waveforms available, as well as a range of unique synthesis types including Phase Modulation, Linear Frequency Modulation, Pulse Width Modulation, HTE Sync, and three types of Phase Distortion. It is capable of 16 voices that can be split and layered in two parts and has the ability to combine voices into stereo binaural voices. The 8 oscillators and 7 synthesis types can then be arranged using one of over 140 preset algorithmic combinations. You can also craft your own custom algorithm and store it in the patch. If this didnt offer enough options, we also feature Algorithm morphing which lets you select 8 algorithms, place them in any order and modulate smoothly between them. This uniquely powerful sound generator is then fed into the powerful Hydrasynth digital filter section, which includes 18 digital filter models as well as morphing and digital drive. From there the sound is further sculpted by a custom analog variable pre-drive circuit for intense analog warmth, before passing into the pure analog, 4-pole resonant filter. This is hybrid synthesis like you have never heard before.
Architecture
16 voices with 8 oscillators per voice
Algorithmic synthesis engine with morphing
Analog filter, hybrid digital / analog signal path
Oscillators
Oscillator modes:
◦ Phase Modulation (PM), Frequency Modulation (FM),
◦ Pulse Width Modulation (PW), HTE Sync, Phase Distortion (3 types)
Over 300 waveforms and 140+ preset algorithms
Custom Algorithm mode for user-defined routing
Filters
Digital filter (18 models including morphing multimode and vowel)
Analog 4-pole low pass filter
Analog filter includes pre-drive saturation, self-oscillation and Q compensation
Modulation
32-slot Modulation Matrix
o 170 total sources
o Over 425 total destinations
5 LFOs Sine, Tri, Saw, Ramp, Square, Random, Noise, and Step
13 DAHDSR envelopes with looping, BPM sync modes and more
8 Macros per patch
Performance Controls
61-key semi weighted Polytouchฎ keybed with polyphonic aftertouch
4 octave Ribbon controller with multiple modes
Chord mode, Octave buttons, and Glide
Dedicated Digital and Analog filter controls
Innovative Envelope Bias controls for intuitive patch adjustment
Arpeggiator & Sequencer
Arpeggiator: 8 modes with Ratchet, Chance, Entropy
Dedicated controls for Mode, Octave, Gate and Entropy
Sequencer: 2 polyphonic note tracks + 1 Macro automation track
Up to 128 steps per track with probability and drift options
Parameters can be modulation destinations in the modulation matrix
Effects
Pre/Post FX: Chorus, Flanger, Rotary, Phaser, Lo-Fi, Tremolo, EQ, Compressor, Distortion
5 delay types with tempo sync
4 reverb types with up to 90s decay and Freeze
Patches
Single mode: 8 banks ื 128 patches
Multi mode : 5 Banks ื 128 Multi patches
Favorites system and randomization options
Connectivity
MIDI In/Out/Thru DIN & USB-B (class-compliant)
CV Pitch, Gate & Clock with 2 Mod inputs and 2 Mod outputs
TRS Balanced outputs
Dual headphone jacks 3.5mm & 1/4
Sustain and expression pedal inputs
ASM Manager patch management and backup
Hardware
Tour-ready metal chassis
Backlit wheels and touch-responsive display
Single/Multi mode buttons and Upper/Lower part selection
Key Specs
16 voices; 8 oscillators per voice
300+ waveforms
140+ algorithms with Custom Algorithm mode
Dual filters: Digital (18 Models) + Analog 4-pole with pre-drive
FX suite: Pre/Post FX, Delays, Reverbs
Full connectivity: MIDI, USB, CV/Gate, audio outputs"
https://www.ashunsoundmachines.com/leviasynth-key?fbclid=IwY2xjawPbOZ1leHRuA2FlbQIxMQBzcnRjBmFwcF9pZBAyMjIwMzkxNzg4MjAwODkyAAEeY-vu3KrxdckAym10UYa2BGkBxBpAv9nX8Dj98yESdgAMkzbKo7jlaPP9xIw_aem_R_v0coUzl1FbT9E1VeLq6w
