Fourm Transpose behaviour with external MIDI
Started by BassistGotFourm, January 15, 2026, 06:36:50 AM
3 Replies 20,136 Views
BassistGotFourm
Commerce
So,
First off... Hi I am David!
Second off... You may gather from my user name that I am not someone with an encyclopaedic knowledge of synthesis - so, be gentle...
One of my plans for the use of the Forum is to play it for bass tones with a foot controller. The ones with the biggest range tend to come with limited onboard control options as they are primarily designed for use with organ SIMs.
So I have been reading the Forum manual on the transpose function which says:
"Transpose
The up and down buttons in the transpose section transpose the keyboard of the Fourm Keyboard (not available on the Module) up or down in octaves. The LED indicates the current keyboard transposition state. Transposing the keyboard also changes the MIDI note numbers of thekeys so that MIDI notes sent are also transposed.
Transpose settings are Param-level and are saved with individual programs. Note that pressing one of the transpose buttons won't affect any keys currently held down. It only affects keys/notes played after you have transposed the keyboard".
What this does not explain is how this will affect external MIDI note messages. From my perspective it might be nice if it did, as that would give me more options pitch range for foot-played sounds.
Anyone have any idea what the transpose behaviour is with external MIDI?
Kind regards,
David
gus
Administrator
Full Member
Hi David,
Welcome! The transpose buttons do affect the external MIDI note. You can think of the Fourm as having a giant keyboard, where the transpose buttons move you up and down octaves, which is mirrored on the USB and DIN MIDI out. Most keyboards with transpose functions work this way.
BassistGotFourm
Commerce
Well that sounds very positive but is it the same on the Fourm for MIDI in?
D
BT
Agents
Jr. Member
The transpose buttons on Fourm will not have any effect on the incoming MIDI stream. This is standard behavior across most synthesizers. Your MIDI controller/DAW/sequencer will determine the octave transposition  and Fourm will respond to this.
