Update of TEO-5 - MIDI-OX issues
Started by OleOlson, December 07, 2025, 06:34:32 AM
7 Replies 27,785 Views
OleOlson
Commerce
Dear Sequential/Oberheim team,
I'm having issues with updating my TEO-5. It's obiously related to MIDI-OX, always turning into a unresponsive state when I try to set the buffer values, which are not saving. And after trying differents approaches led by chatgpt for about two hours now, I'm really disappointed by this and find no solution to get MIDI-OX running properly on my recently set up Windows 11 PC.
Frist of all I want to ask you for help or alternatives to MIDI-OX? Already tried Erriez MIDI‑SysEx IO, also didn't work.
Second, I really wonder about the still very outdated update procedure for the device, relying on an outdated and not really maintained third party software as main tool for updating a recently release 1.500€ expensive synth, that actually has an USB port! For me as a python dev it's absolutely not understandable, why the customer has to use a buggy and problematic software in 2025 to update the synth instead of a simple and by Sequential/Oberheim maintained application.
OleOlson
Commerce
After now four hours of searching, I was able to fix it. Your explanation is just misleading - trying do change buffer sizes in "Configure buffers ..." leads to crashes of MIDI OX - even in a Win10 VM. After searching more and doing the set up like for the Hexinverter Mutant Brain Eurorack Module, a simple screenshot was the explanation what was different. Wrong config window!
I then set it up as Hexinverter suggests -> by going to "SysEx..." and then change the config under "SysEx" -> "Configure..." where a simple adjustment of the delay to 100ms did the job.
Overall this wasted me pretty much time, so I would appreciate a reason why I had to fight with a software tool, that was last time updated 17.06.2010. Elektron is also able to provide a solution for SysEx updates in a 2025 manner, as example.
Elric
Full Member
Peak Oil
  With Sequential's team being so small their software support is pretty terrible. This has bugged me for a long time.  The firmware updating is the worst. And the lack of a free computer control interface is bad too. Most companies have these now. And the separate company that charges $100 for buggy software isn't good.
  And the lack of updates for the synths is disappointing as hell. The Pro 3 should have a solid 2.0 update.
:Elric:
OleOlson
Commerce
I understand that they are a small team. But relying on an outdated buggy software like MIDI OX as the main and only updating tool for their windows customers is a bit cheap and for me a no go professionally.
From a dev perspective its a 1 - 2 weeks one person project, easily transferable to other synths with usb ports in their product portfolio, and I assume that most future products will have one. And it's really not rocket science, writing a tool that only recognizes the usb devices connected, let the user select the sequential/oberheim synth he wants to update, and send the SysEx file he selects. You don't need any deep synth software know how for this, so also no problem to outsource the project.
protoculture
Commerce
They are not a small team at least potentially. They are owned by Focusrite. Its up to them to assign additional resources.
joachip
Commerce
Couldn't the firmware be distributed using normal .mid files instead?
Lots of DAWs can read and write these, and then we wouldn't have to struggle getting the ancient MidiOx software to run.
DavidDever
Full Member
Audio Software Developer
For reference: https://devblogs.microsoft.com/windows-music-dev/windows-midi-services-rollout-known-issues-and-workarounds/
I cannot speak to this on Focusrite / Sequential / Oberheim's behalf, though I suspect it's not a great use of limited resources, chasing platform-specific issues that require OS-level fixes, compared to actual firmware development work itself.
OleOlson
Commerce
As I ran again into hours of issues with MidiOX, even without changing any setting in MidiOX after up/downgrading between stable and beta firmware one week before, AI suggested using the free tool SendSX by Bome Software instead.
It allows updates like I'm used to - select device, select update file, send - transfer starts and device updates afterwards. No buffer/delay settings, no nonsense error messages. And a tool by an operating company, not an outdated/unmaintained software relic.
Great tool, really suggest trying it out: https://www.bome.com/products/sendsx
Uninstalled buggy MidiOX  >:( immediately after finding out that SendSX does the job reliable.
