OBX8- anyone else have trouble controlling parameters of a double over usb?
Has anyone had success controlling parameters of a split, double, or binaural patch over usb? For example, when i try to control the filter freq, over midi cc or through the sound tower plugin, it does not work. With enough finagling, sometimes it effects one of the patches. But it hasn't really worked correctly for me thus far.
I followed the recommended steps of turning off local control also.
This is my problem as well. It works when I turn, for example, the cutoff knob on the OBX8, but it doesn’t work at all when using SoundTower or MIDI CC. I experimented with it for quite some time.
When Double/Split/Binaural mode is active and you’re using SoundTower, you have to automate two separate cutoff MIDI CCs for both programs. With the new Prophet 10 OS upgrade, it’s no problem at all to control both programs simultaneously.
Any news, help, or info on when this will be sorted out would be very much appreciated.
« Last Edit: February 02, 2026, 05:33:57 AM by cc2283 »
