Latest firmware updates have added a lot of new features.
This is great. Thanks Sequential !
However, the additional settings make the whole Program set of settings a bit ambiguous and cluttered.
It would be great if some settings could be renamed or grouped together according to their function.
« Env Retrig » could be renamed « Unison Env Retrig » to better distinguish from « Env Repeat » and grouped with other Unison settings.
The « Arp Relatch » and the new « Arp Timing » could be grouped together.
The Program settings could look something like that (renamed and moved settings are respectively in italics and underlined) :
1. Osc1 KeyFollow
2. Osc2 KeyFollow
3. Osc2 Filt Bypass
4. Osc1 Glide
5. Osc2 Glide
6. Osc1 Fine Freq
7. Osc2 Fine Freq
8. Glide Mode
9. Unison Key Mode
10. Unison Env Retrig
11. Unison Voices
12. Unison Detune
13. Key > LPF Freq
14. LFO1 Reset
15. LFO2 Reset
16. LFO1 Slew
17. LFO2 Slew
18. PitchBend Up
19. PitchBend Down
20. Env Repeat
21. Env1 Delay
22. Env2 Delay
23. Overdrive Mix
24. Noise Type
25. Arp Relatch
26. Arp Timing
27. Scale
28. Prog Volume
I fully understand that the settings numbering must be kept internally or in the SysEx format for compatibility, but the settings order in the display could be different.
Anyway, thanks Sequential for your continued support of the T5 !
