Is octave transpose ever coming?
Started by acemonvw, October 04, 2025, 12:15:40 PM
9 Replies 31,879 Views
acemonvw
Commerce
Logged
I know I've asked (both in requests to Sequential, and mentioned in feature requests here)... but it's really the only thing I'd love to see on the Prophet 10. It seems like it would have been fairly simple to implement, but it never came. I believe one of the developers even mentioned on reddit a few years ago (in reply to me) that it was coming but that they had to work through some things to get it. But a new update came out in May of 2025, and it wasn't included. I was surprised to see any new updates since 2020, so it was nice to see some activity on it...
All it needs to do is replace the note priority (which doesn't need to have a single hand perform the action) whereby pressing "KEYBOARD + Group select/Bank Select transposes up or down. Note priority could be moved to the filter keyboard button.
Or, if moving note priority is a problem, just hold LO FREQ and press Group select or Bank select (Dec/Inc). I wouldn't really be bothered by that. Would be nice to have the P10 as a master controller in that sense, or to quickly move between octaves.
558
Jr. Member
Logged
#1
Are you talking about a Module?  Wouldn't it just have to apply this to every voice like 20 cards (2 osc x 10 voices)?  Since there is no keyboard.  And in that situation you are able to transpose MIDI in your Daw or select up or down octave on the controller you are using.
I mean if they had included buttons originally (on the full Keyboard P10 r4) that somehow altered the keys that were pressed like some small 2 octave or 3 octave synths and MIDI controllers have, that would be something.  But this is a 5 octave synth with a 4 octave frequency range to the oscillators.  There are also a lot of ways to modify those 4 octaves.  The Lo Freq, the sync button, the LFO MOD and Poly MOD both can change it, as well as lowering your filter cutoff.  Just a lot of ways to get very low low pitches and very high high frequencies.  I don't see why this is necessary.  Just my 2c since I never needed this.
Prophet still sounds good.  With my setup I only need to play like once a month.  First take perfect albums with detailed video of the creation.  Anywhere from 20 minutes to 2 hours or longer.
acemonvw
Commerce
Logged
No - the keyboard itself. Most (modern) keyboards, including 61 key synths, have octave transpose buttons to move up and down 12 semitones quickly. I don't think the module was out back in 2020 when octave transpose was requested. I certainly do not think a module would (or should) have this feature, because modules don't need to send MIDI note data, so hopefully this clarifies that point.
It may not be necessary to you, I get that. However, I use octave transpose quite a bit with my setup (and I am not the only one to have requested this. Of course you can 'change the frequency range of the oscillators,' but that occurs at single semitones and would not affect MIDI data, so if you used the P10 as a master controller for your set up, you are out of luck, especially if you want to hit note values that are above or below what the 61 keys offer.
If you think it is irrelevant, then we could ask why most 61 key synths, including the OBX8, Virus TI 61, Prophet 12, UDO Super 8, Super Gemini, Poly Evolver, P08/REV2, and countless others have this feature? They too have large ranges, many ways to modify their sounds. The point is: It is an extremely useful feature for 1) quickly getting to semitones that you can't access within the 61 keys, 2) modifying the sound without shifting the semitone potentiometers, and 3) more easily sending MIDI note data that corresponds with notes outside the standard 61 key range.
Analog Prophet
Full Member
Logged
Quote from: acemonvw on October 04, 2025, 08:50:03 PM
That would be helpful. But anyhow, some people has wrong expectations of the P5/10 rev 4 of what it is and what it's not: It is a legacy of a vintage synth and I'm happy it's not something else than just a Prophet 5/10 - that's why I bought it.
Mat
Commerce
Logged
Something that's missed here too, would be very useful.
louis
Commerce
Logged
Agree. It's extremely annoying this haven't been added yet.
ko-bra
Commerce
Logged
Yes, octave transpose functionality should be added.
It seems it's the most requested feature since this beauty was released, and I can't imagine it being impossible to implement.
Unless there's a principle of some kind that prevents them for doing it.
nunucello
Jr. Member
Logged
acemonvw
Commerce
Logged
Three years ago cbmd wrote this in reply to me on reddit (here):
QuoteIt's definitely on our list and something we considered for addition this time around. However, we identified some potential operational gotchas and felt that the feature should be better thought through and designed before implementation.
Not to worry, we heard you and the feature is still on our radar.
I can't imagine they're still going to work on it though, especially if new firmware has been released, excluding this.
acemonvw
Commerce
Logged
I messaged the folks at Sequential and the reply was:
QuoteWe purposely left transpose switches out to keep in line with the vintage Prophet 5/10.  We have implemented a few features already that require multiple button combinations (a thing we try to steer clear from to keep the front panel as simple as possible) and as the synth is feature complete, we likely will not be adding any transpose options.  However, I will put it on the feature request list should we ever look into adding this.
I find this reasoning to be somewhat unconvincing. Sequential has consistently invoked "keeping it in line with the vintage P5/10" as the reason transpose won't be added, and yet the 2.0.4 firmware update added Q compensation, adjustable velocity and aftertouch per patch, and layer linking, none of which existed on the originals. So the "vintage fidelity" argument only seems to apply selectively to a feature that's highly requested.
What makes this especially frustrating is that a developer acknowledged the request years ago (see my previous post), and said it was still on their radar... They cited "operational gotchas" they needed to work through and implied it was a matter of when, not if. To now hear "the synth is feature complete" and "we likely will not be adding any transpose options" feels like a quiet reversal with no real explanation. Further, they mention that they want to keep the front panel as simple as possible, but that is also is strange given that Q compensation requires multiple button presses (Filter REV + buttons 1-8). I'd personally accept one more button combination to gain a feature I'd actually use. Split/stack is already there behind button presses I never use, and it doesn't affect my experience of the synth at all.
This request is not new... there are other requests for the same thing with no traction or formal reply. Just some work-arounds such as spending $1000+ on the Yorrick LFE machine (which is a cool device, though no longer produced anyway), as well as other MIDI devices.
It remains a consistently requested feature with no satisfying explanation for its absence.
