Logic MIDI out -> P5(R4) -> Logic audio in
« on: September 30, 2025, 11:40:20 PM »
Noob here re getting my P5 to play the MIDI from Logic Pro X. I’m hearing I need to first go back to a DIN cable instead of USB but more broadly could anyone walk me through their process of setting up the track(s) routing in Logic and the settings on the P5? I’ve looked online and even asked ChatGPT but I can’t find anything that clearly explains it. Thank you in advance!
Re: Logic MIDI out -> P5(R4) -> Logic audio in
« Reply #1 on: October 01, 2025, 01:37:18 AM »
From start, if I recall right, Sequential recommended to use DIN instead of USB MIDI for things such firmware update, but not any longer. Anyhow, some MIDI interfaces works better than others, and vice versa. What particular MIDI interfaces are listed at the text file to firmware update (and my point here is not just for firmware update, but interfaces that might be problematic).
